About the home assistant integration standard weather API for call
Our company wants to develop a home assistant with multiple sensors that can be integrated to receive and display. I would like to know if Home Assistant has a weather API that supports multiple sensors that can be called, such as multi-channel temperature, humidity, wind speed, wind direction, rainfall, UV index, lightning pressure. pm2.5
You can create your own: Creating your first integration | Home Assistant Developer Docs.
Use an existing integration:
Or see what others are doing:
Definitive guide to Weather integrations 🌦.
If your company is wanting to work with Home Assistant, this program may be helpful to them.
https://partner.home-assistant.io/
Probably a language barrier, but that sentence doesn’t make much sense.
Are you planning:
  • To implement HA: then what do you mean by develop?
  • Develop a device with multiple sensors that pushes to HA? Then you’ll (probably) need to create an integration as said above
  • Develop a device that pulls from HA? See the API here: REST API | Home Assistant Developer Docs
