? about upgrade in regards to time
I just updated to 86.2 and believe it or not I think it all went perfect.
I saw something in the notes about time. I have 1 single test automation that uses the time platform.
Just need to change the name from time to Time_pattern?
Thanks.
depends on what the time is - check the docs… If its an absolute time ‘10:00:00’ for example it will be ok. If it’s triggering every 5 mins then you need to use time_pattern now
It’s at 21:27:00 so should be ok.
Thank you!
