I live above the polar circle, and here it is now midnight sun (up 24 hrs/day) until July 23rd.
But, the sun.sun state claims it is ‘below horizon’ (!) and, well, lucky us it is ABOVE for the next 7 weeks.
How can I fix this?
How can I fix this?
At the very least, you can open an issue against the sun component. If you know Python, then you can submit a PR against the source that corrects the behaviour.
@Tinkerer Ahh, so this is possibly a bug then?
No, my Python skills are not good and I can’t make a PR.
Are the latitude & longitude correct in your configuration file?
@anon34565116 Yes sir, I’m 100% sure.
Before the midnight sun started, sunrise/sunset was 100% correct.
An elevation of 23.7 and below horizon… I’d call that a bug
OK, I think they should open an issue with details such as lat/long so it could be replicated.
An idea for a ‘dirty fix’ - creating an automation which says between May 21 and July 26 - set sun.sun state to 'above_horizon’
Anybody who are good at automations that might help me with that? Please?
use numerical states and check the sun elevation being greater than zero
platform: numeric_state
entity_id: sun.sun
# Optional
value_template: '{{ state.attributes.elevation}}'
# At least one of the following required
above: 0
But that my never trigger if it’s always above zero. If that’s what you want, make the change.
Thanks.
Near the end, the link text is correct but the link itself is wrong.
URL fixed
- above: '0'
entity_id: sun.sun
- condition: state
entity_id: sun.sun
state: above_horizon
…didnt change the sun.sun state after pressing ‘trigger’ of the automation
One of the challenges to resolve this issue is that in order for trigger
to activate the automation, sun.sun
must experience a state-change. In other words its state has to change from below_horizon
to above_horizon
to cause it to trigger the automation. However, that’s not going to happen for the next 7 weeks.
Similarly, testing for above: 0
requires it to first go below 0 then rise above it to cause trigger
to activate the automation. It won’t dip below 0 for another 7 weeks.
