Hi!
I’m not sure if I’m doing something wrong, but I’d like to get the absolute value of a variable (e.g. sun elevation).
as per
Templating - Home Assistant (home-assistant.io) which says taht we can use Mathematical operation ( Template Designer Documentation — Jinja Documentation (3.0.x) (palletsprojects.com)) why won’t the template
states.sun.sun.attributes.elevation < ((states.variable.max_sun_position.state|float) * (0.96-((abs((now().month-6)*2))/100)))
work?
Am I missing something?
Thank you for your input!
