I use mobile notification through Node Red and some automation, and I just changed my phone and realized I have to change all the notifications.
Can I abstract the name of the entity?
Like I name haz_mobile: current entity name for my phone.
Then use haz_mobile for all automations.
So when I change my phone, I just change the name in one spot, and all my automations work.
You can set a āglobalā variable as text that you can template into your stuff. You can use a helper for that
Or this: Trigger based template sensor to store global variables.
There is also some magic I think if you name the new entity_id exactly the same as the old entity_id that the new one might just work. I havenāt tried that, but heard about it.
why not set the name of your mobile app client itself? such that it doesnāt get a new name each time⦠thatās part of the purpose of entity id friendly namesā¦
just like if you light.kitchen phyical light breaks and you replace it with a new one, you wouldnāt go and change all your automation to light.kitchen_new⦠youād name the new one light.kitchen
I installed the new app
I changed the friendly name to Haz Mobile
I see the device listed is indeed haz_mobile, with all of its entities
I am not able to get it in the drop-down of the Node Red āEdit Call Service Nodeā.
I restarted Node Red, restarted Home Assistant, still, donāt get it. I get the first device name which was set when I first installed the companion on the new phone.
So everything works on the HA side, but not Node Red yet. Am I missing a step to refresh the Node Red device list?
First deploy any ha node, then check the auto complete again. No? Go into any HA node the server dropdown, there is only one server? Yes, click the edit button next to the server and uncheck the cache autocomplete. deploy and then restart nodered.
