The latest ESPHome update approx 48 hours ago appears to have crippled my air conditioner controller for my home lab.
No code changes have been made for months, and everything has been working fine. After the ESPHome update some 48 hours ago the following occurs… see logs below.
[14:30:59][D][sensor:094]: 'Studio AC Inside Temperature': Sending state 24.00000 °C with 1 decimals of accuracy
[14:31:29][D][dallas.sensor:153]: 'Studio AC Inside Temperature': Got Temperature=24.0°C
[14:31:29][D][sensor:094]: 'Studio AC Inside Temperature': Sending state 24.00000 °C with 1 decimals of accuracy
[14:31:59][D][dallas.sensor:153]: 'Studio AC Inside Temperature': Got Temperature=24.1°C
[14:31:59][D][sensor:094]: 'Studio AC Inside Temperature': Sending state 24.06250 °C with 1 decimals of accuracy
[14:31:59][D][binary_sensor:036]: 'Studio AC Climate': Sending state ON
[14:31:59][D][climate:011]: 'Aircon Studio' - Setting
[14:31:59][D][climate:015]: Mode: COOL
[14:31:59][D][climate:024]: Fan: AUTO
[14:31:59][D][climate:040]: Target Temperature: 23.00
WARNING esp5-studio-ac @ 192.168.0.124: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for esp5-studio-ac @ 192.168.0.124
WARNING Disconnected from API
INFO Successfully connected to esp5-studio-ac @ 192.168.0.124 in 0.006s
INFO Successful handshake with esp5-studio-ac @ 192.168.0.124 in 0.029s
[14:32:43][D][esp32.preferences:114]: Saving 1 preferences to flash...
[14:32:43][D][esp32.preferences:143]: Saving 1 preferences to flash: 1 cached, 0 written, 0 failed
[14:33:00][D][dallas.sensor:153]: 'Studio AC Inside Temperature': Got Temperature=24.1°C
[14:33:00][D][sensor:094]: 'Studio AC Inside Temperature': Sending state 24.06250 °C with 1 decimals of accuracy
[14:33:00][W][script:060]: Script 'ac_timer' is already running! (mode: single)
[14:33:00][D][main:138]: Telling Climate to START
[14:33:00][W][component:237]: Component dallas took a long time for an operation (54 ms).
[14:33:00][W][component:238]: Components should block for at most 30 ms.
[14:33:30][D][dallas.sensor:153]: 'Studio AC Inside Temperature': Got Temperature=24.1°C
[14:33:30][D][sensor:094]: 'Studio AC Inside Temperature': Sending state 24.12500 °C with 1 decimals of accuracy
[14:33:30][W][script:060]: Script 'ac_timer' is already running! (mode: single)
[14:33:30][D][main:138]: Telling Climate to START
[14:33:30][W][component:237]: Component dallas took a long time for an operation (55 ms).
[14:33:30][W][component:238]: Components should block for at most 30 ms.
[14:34:00][D][dallas.sensor:153]: 'Studio AC Inside Temperature': Got Temperature=24.1°C
[14:34:00][D][sensor:094]: 'Studio AC Inside Temperature': Sending state 24.12500 °C with 1 decimals of accuracy
[14:34:00][W][script:060]: Script 'ac_timer' is already running! (mode: single)
[14:34:00][D][main:138]: Telling Climate to START
[14:34:00][W][component:237]: Component dallas took a long time for an operation (51 ms).
[14:34:00][W][component:238]: Components should block for at most 30 ms.
[14:34:30][D][dallas.sensor:153]: 'Studio AC Inside Temperature': Got Temperature=24.2°C
[14:34:30][D][sensor:094]: 'Studio AC Inside Temperature': Sending state 24.18750 °C with 1 decimals of accuracy
[14:34:30][W][script:060]: Script 'ac_timer' is already running! (mode: single)
[14:34:30][D][main:138]: Telling Climate to START
INFO Successful handshake with esp5-studio-ac @ 192.168.0.124 in 0.033s
[14:35:34][D][dallas.sensor:153]: 'Studio AC Inside Temperature': Got Temperature=24.2°C
[14:35:34][D][sensor:094]: 'Studio AC Inside Temperature': Sending state 24.18750 °C with 1 decimals of accuracy
[14:35:34][D][main:181]: AC Timer is ON
[14:35:34][D][main:138]: Telling Climate to START
Seems this is the offending issue… loss of API connection.
Haven’t ever seen this occur previously, so not sure why it has all of a sudden started happening? Open to work arounds if anyone has any?
Here’s the code…
esphome:
platform: ESP32
board: esp32doit-devkit-v1
on_boot:
# - wait_until:
# condition: api.connected
- delay: 2s
- script.stop: ac_timer
- climate.control:
mode: 'off'
- mqtt.publish:
topic: HomeAssistant/Studio/Aircon/Status
payload: "OFF"
# Enable logging
logger:
# level: VERBOSE
# Enable Home Assistant API
api:
reboot_timeout: 0s
ota:
password: !secret esp5-studio-ac-ota
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp32-Ir-Test Fallback Hotspot"
password: "<REDACTED>"
captive_portal:
status_led:
# pin: GPIO2
pin:
number: 2
ignore_strapping_warning: true
#Temperature Sensor Pin
dallas:
- pin: 23
update_interval: 30s
mqtt:
# broker: !secret mqtt_broker
username: !secret mqtt_login
password: !secret mqtt_passwd
port: 1883
reboot_timeout: 0s
keepalive: 60s
discovery: false
# IR TRansmitter entry
remote_transmitter:
pin:
number: 18
carrier_duty_percent: 50%
climate:
- platform: daikin
supports_heat: false
transmitter_id: ir_transmit
script:
- id: ac_timer
then:
- binary_sensor.template.publish:
state: ON
- logger.log: "AC Timer is ON"
- delay: 20min
state: OFF
- logger.log: "AC Timer is OFF"
binary_sensor:
name: "Studio AC Climate"
on_press:
then:
- climate.control:
mode: "COOL"
fan_mode: AUTO
target_temperature: 23°C
- mqtt.publish:
payload: "ON"
- logger.log: "AC is ON"
on_release:
then:
- climate.control:
mode: "OFF"
- mqtt.publish:
payload: "OFF"
- logger.log: "AC is OFF"
# Studio Inside temperature sensor
- platform: dallas
resolution: 12
address: 0x2401204FD9422728
name: "Studio AC Inside Temperature"
on_value:
then:
- if:
condition:
# Is the inside temp higher than 24
- lambda: 'return id(in_ac_dallas).state > 24;'
then:
# Start the AC
state: on
- script.execute: ac_timer
- logger.log: "Telling Climate to START"
- if:
condition:
and:
# Is the Outside temp under 18
- lambda: 'return id(out_temp_studio).state < 18;'
# Is the inside temp lower than 23
- lambda: 'return id(in_ac_dallas).state < 23;'
- binary_sensor.is_off: timer_status
then:
state: off
- logger.log: "Telling Climate to STOP"
# Studio Outside Temperature from HA
- platform: homeassistant
name: "Studio Outside Temperature"
entity_id: sensor.studio_temp_out
