Blueprint: AC Drying Mode with Restore Option
Description:
This blueprint automates the drying mode for your air conditioner (AC) when it is turned off from ‘cool’ mode. Once the AC is turned off, it will switch to fan_only mode for a specified drying time. After the drying period, the AC can either restore its previous settings (mode, temperature, and fan) or turn off completely. This prevents moisture buildup inside the unit, which can help reduce odors and prolong the life of your AC.
Features:
- Automatic Drying: When your AC is turned off from
coolmode, it automatically switches tofan_onlymode for a user-defined period. - Restore Settings: Optionally restore the previous settings (mode, temperature, fan) after the drying period ends.
- Customizable Drying Time: Set the drying time from 1 second up to 1 hour.
How It Works:
- Trigger: The blueprint is triggered when the AC changes from
coolmode tooff. - Action:
- Switch the AC to
fan_onlymode for a specified drying time. - If
restore_last_stateis enabled, it restores the previous settings after the drying time. - Finally, the AC is turned off unless it was manually interrupted.
- Switch the AC to
Inputs:
- Climate Entity: The climate entity for your AC (e.g.,
climate.living_room_ac). - Drying Time: The duration (in seconds) for how long the AC should run in
fan_onlymode before turning off. Defaults to 600 seconds (10 minutes). - Restore Last State: Boolean option to restore the AC’s previous settings after the drying period. Defaults to
true.
Blueprint YAML:
blueprint:
name: AC Drying Mode with Restore Option
description: >
This blueprint automates the drying mode for your AC. If the AC is turned off from 'cool' mode, it will switch to 'fan_only' mode for a specified drying time and then optionally restore the previous settings before turning off unless interrupted.
domain: automation
input:
climate_entity:
description: The climate entity for your AC (e.g., climate.my_ac_name).
selector:
entity:
domain: climate
drying_time:
description: Time in seconds to run the AC in fan_only mode before restoring previous settings and turning it off.
default: 600
selector:
number:
min: 1
max: 3600
unit_of_measurement: seconds
mode: box
restore_last_state:
name: Restore Last State
description: Choose whether to restore the AC's last state (mode, temperature, fan) after the drying period.
default: true
selector:
boolean:
- platform: state
entity_id: !input climate_entity
to: 'off'
condition: []
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- variables:
climate_entity: !input climate_entity
restore_last_state: !input restore_last_state
previous_hvac_mode: "{{ states(climate_entity) }}"
previous_temperature: "{{ state_attr(climate_entity, 'temperature') }}"
previous_fan_mode: "{{ state_attr(climate_entity, 'fan_mode') }}"
- service: climate.set_hvac_mode
hvac_mode: fan_only
- wait_for_trigger:
- platform: state
timeout: !input drying_time
continue_on_timeout: true
- choose:
- conditions:
- condition: state
state: 'fan_only'
sequence:
- choose:
- conditions:
- condition: template
value_template: "{{ restore_last_state }}"
sequence:
- service: climate.set_temperature
temperature: "{{ previous_temperature }}"
- service: climate.set_fan_mode
fan_mode: "{{ previous_fan_mode }}"
hvac_mode: "{{ previous_hvac_mode }}"
- delay: 00:00:01
- service: climate.turn_off
mode: restart
How to Use:
- Manually:
- Copy the YAML code into a new automation blueprint in your Home Assistant instance.
- Configure the inputs according to your setup.
- Save and enjoy an automatically maintained AC with drying functionality.
Notes:
- Ensure that your climate entity supports fan_only mode for this blueprint to function correctly.
- The blueprint has been set to restart mode to handle cases where the automation might be triggered multiple times.
Download & Feedback:
Feel free to download, modify, and share feedback on this blueprint. If you encounter any issues or have suggestions for improvements, please comment below!
