AC fan speed control - up & down glance buttons
Hi, I would like to have up & down icons to put my AC fan speed up & down. Each as it’s own glance icon in the front end.
The speeds that the AC (Mitsubishi) are; minimum, low, medium-low, medium-high, high, auto. I am using @scotty’s Echonet component to integrate with climate; climate.mitsubishi_lounge
Originally I was thinking of having the up arrow have lots of conditional entries and pending what speed it is currently then it goes to the next speed. Likewise the down arrow to do the same but opposite. However, I am not sure if this is the best way and if I am complicating it too much?
@123 do you think it would be an idea to set each speed as per your example in this.
Ie. Minimum = 1, low = 2, medium-low = 3, medium-high = 4, high = 5
The linked post shows how to use a dictionary to simplify an existing template. I don’t know how you intend to apply that to your application. Post some code and we’ll see what can be done.
@123 This is what I have so far… It is currently all being controlled in lovelace
          - type: conditional
            conditions:
              - entity: climate.mitsubishi_lounge
                state_not: 'off'
              - entity: sensor.mitsubishi_lounge_ac_fan_speed
                state: 'Minimum'
            card:
              type: glance
              entities:
                tap_action:
                  action: call-service
                  service: browser_mod.more_info
                  service_data:
                    title: Mitsubishi Airconditioner
                    entity_id: climate.mitsubishi_lounge
                    deviceID: this
                title: "Min to Low"
                show_name: false
                show_state: false
                icon: mdi:fan
                tap_action:
                  action: none
                title: "Min to Low"
                show_name: false
                show_state: false
                icon: mdi:fan-chevron-up
                tap_action:
                  service: climate.set_fan_mode
                  service_data:
                    fan_mode: low
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'Low'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                title: "Low to Min"
                show_name: false
                show_state: false
                icon: mdi:fan-chevron-down
                tap_action:
                  service_data:
                    fan_mode: minimum
                title: "Low to Med"
                show_name: false
                show_state: false
                tap_action:
                  service_data:
                    fan_mode: medium-low
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'Medium'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                title: "Med to Low"
                show_name: false
                show_state: false
                tap_action:
                  service_data:
                    fan_mode: low
                title: "Med to High"
                show_name: false
                show_state: false
                tap_action:
                  service_data:
                    fan_mode: medium-high
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'High'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                title: "High to Medium"
                show_name: false
                show_state: false
                tap_action:
                  service_data:
                title: "High to Turbo"
                show_name: false
                show_state: false
                tap_action:
                  service_data:
                    fan_mode: high
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'Turbo'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                title: "Turbo to High"
                show_name: false
                show_state: false
                tap_action:
                  service_data:
                title: "Turbo"
                show_name: false
                show_state: false
                icon: mdi:fan-plus
                tap_action:
                  action: none
          - type: conditional
            conditions:
                state: 'off'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                title: "Off"
                show_name: false
                show_state: false
                icon: mdi:fan-off
                tap_action:
                  action: none
                title: "Off to Min"
                show_name: false
                show_state: false
                tap_action:
                  service_data:
                    fan_mode: minimum
It feels very convoluted though, I am sure there must be a better way
For those that may stumble upon this, I am trying to achieve an up & down glance style button to make my AC go lower/higher. My method was using conditional cards to do this and I couldn’t work out how to have glance buttons next to them without making the entire row for every circumstance. So, it has ended up being quite a lot of yaml code in lovelace. There is essentially two lots of conditional rows for every speed situation. Here is my current code so you can get an idea.
        - type: custom:stack-in-card
          cards:
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'Minimum'
            card:
              type: glance
              entities:
              - entity: switch.fanpower
                tap_action:
                  service: browser_mod.popup
                  service_data:
                    title: Dyson Fan Controls
                    deviceID: this
                    card:
                      type: glance
                      entities:
                        tap_action:
                          action: toggle
                      - entity: switch.fan_auto
                        tap_action:
                          action: toggle
                      - entity: switch.fan_night
                        tap_action:
                          action: toggle
                      - entity: switch.oscillation
                        tap_action:
                          action: toggle
              - entity: script.bed_time
                show_state: false
                icon: mdi:bed
                tap_action:
                  action: toggle
                title: "Min to Low"
                show_name: false
                show_state: false
                tap_action:
                  service_data:
                    fan_mode: low
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'Low'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                    card:
                      type: glance
                      entities:
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                show_state: false
                icon: mdi:bed
                tap_action:
                  action: toggle
                title: "Low to Med"
                show_name: false
                show_state: false
                tap_action:
                  service_data:
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'Medium'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                    card:
                      type: glance
                      entities:
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                show_state: false
                icon: mdi:bed
                tap_action:
                  action: toggle
                show_name: false
                show_state: false
                tap_action:
                  service_data:
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'High'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                    card:
                      type: glance
                      entities:
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                show_state: false
                icon: mdi:bed
                tap_action:
                  action: toggle
                show_name: false
                show_state: false
                tap_action:
                  service_data:
                    fan_mode: high
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'Turbo'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                    card:
                      type: glance
                      entities:
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                show_state: false
                icon: mdi:bed
                tap_action:
                  action: toggle
                title: "Turbo"
                show_name: false
                show_state: false
                icon: mdi:fan-plus
                tap_action:
                  action: none
          - type: conditional
            conditions:
                state: 'off'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                    card:
                      type: glance
                      entities:
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                        tap_action:
                          action: toggle
                show_state: false
                icon: mdi:bed
                tap_action:
                  action: toggle
                title: "Off to Min"
                show_name: false
                show_state: false
                tap_action:
                  service: climate.set_hvac_mode
                  service_data:
                    hvac_mode: cool
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'Minimum'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                title: "Min to Low"
                show_name: false
                show_state: false
                icon: mdi:fan
                tap_action:
                  service_data:
                    hvac_mode: off
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'Low'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                title: "Low to Min"
                show_name: false
                show_state: false
                tap_action:
                  service_data:
                    fan_mode: minimum
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'Medium'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                title: "Med to Low"
                show_name: false
                show_state: false
                tap_action:
                  service_data:
                    fan_mode: low
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'High'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                show_name: false
                show_state: false
                tap_action:
                  service_data:
          - type: conditional
            conditions:
                state_not: 'off'
                state: 'Turbo'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                show_name: false
                show_state: false
                tap_action:
                  service_data:
          - type: conditional
            conditions:
                state: 'off'
            card:
              type: glance
              entities:
                tap_action:
                  service_data:
                    deviceID: this
                show_state: false
                show_icon: false
                title: "Off"
                show_name: false
                show_state: false
                icon: mdi:fan-off
                tap_action:
                  action: none
Below is shots of what it looks like in action:
Lowest
screenshot.2021-02-11
Low
screenshot.2021-02-11 (1)
Medium
screenshot.2021-02-11 (2)
Of course I am sure there must be an easier/cleaner way of doing this, but, this is what I have for the time being…
