AC fan speed shown in HA does not match the actual AC fan speed
My first post here and a new user of Home Assistant.
I control my AC with Home Assistant. When I set the fan speed to low in HA the actual AC fan speed is low. When I set the fan speed to medium the AC fan speed is on high. When I set the fan speed to high the AC fan speed is medium. So the medium and high fan speed are swapped (in HA only).
I use a Remotec ZXT-120 (Z-Wave) device to send the IR signal to the AC. This device is added to my Fibaro Home Center 2. Everything works great in the Fibaro UI.
I installed the Fibaro plugin to HA and added the thermostat as a device to my dashboard to control the AC. When I set the fan speed to high in HA and then open the Fibaro UI I see it’s set to medium what is correct.
Is there a way to swap the medium and high fan speed settings in HA?
Thank you in advance!!
