AC Freedom
Ac freedom app is used to control more than 10 AC brands in the market. Integration to control these would be great for many people in the community.
Integration for Homebridge is also available.
I totally agree with you, it would help a lot to control everything from one app.
I would like to be able to use Fahrenheit instead of Celsius in the AC Freedom app. Is this possible or a feature request?
Good afternoon
Are we still unable to integrate AC Freedom devices into HA?
Thanks!
I have a good news. I noticed that it’s possible to connect AC Freedom to alexa and google home (GH). After adding AC to GH I installed Google assistant SDK plugin to HA and made template to send commands “turn on/off AC” to GH from HA
It works, and if GH added support for AC Freedom it is time to make support for HA.
Is it just On and Off? I can only switch AC on and off from google home…
From Google home we can indeed only turn it on or off. But I’ve seen a workaround to get Home Assistant to communicate directly with the airconditioner, with heat setting etc. So also from me the request to Home Assistant developers: please add it to Home Assistant!
Take a look at hist solution, it is working for me:
Last solution works for me too.
I leave you a post of how to configure an HTW A/C from zero, using A/C Freedom and AUX:
https://community.home-assistant.io/t/htw-s035ix69-a-c-in-home-assistant-from-zero/916874
