Ac Infinity (S-series Fan)
I’m trying to achieve to control the fan via home assistant. First of all here’s what i’ve tried to do.
https://www.rollitup.org/t/idiots-guide-to-getting-an-esp32-to-control-ac-infinity-cloudline-ec-fans-esphome-ha.1053910/
So following the thread I tried the 2 methods ( optocoupler and mosfet) that could acheive the result wanted. But both does no seem to work. Here’s the wiring i’ve tried. For the mosfet version the onboard LED does not light up (tried 2 boards) could be DOA’s so i ordered others just in case (if it happen to be the parts used i’ll update the post)
Optocoupler:
Here’s my yaml file (the Integration does show up in HA fyi)
esphome:
esp32:
  board: nodemcu-32s
logger:
api:
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Grow-Tent-Fan-Temp"
    password: !secret wifi_backup_password
captive_portal:
output:
  - platform: ledc
    pin: GPIO5
    inverted: true
    frequency: 1000
fan:
  - platform: speed
    output: intake_fan_op
    name: "Tent intake fan"
    speed_count: 10
UPDATE:
1- The octocoupler i had in my possession were DOA
2- There’s no 2 method, the octocoupler is on the Esp32 side and the Mosfet is on the Fan controller box !
Wid you get this working in the end?
Hey I know it’s almost a year old. But yes, I got it working with the optocoupler I had DOA’s
Does your fan have the molex connector or the newer style? Sounds like on the op linked forum some internal stuff to the fan changed perhaps.
Have one on order so it will be the newer style.
A friend of mine who knows far more about electrical engineering than I do kept trying to dissuade me from using any of the earlier proposed options because the fan risks leaking full line voltage over a shared ground connection. He was in the process of designing something to better isolate everything when he realized that the Shelly RGBW2 does all of this and doesn’t require any special setup besides some ESPHome config.
I then took things a bit overboard because the Shelly provides additional PWM connections for some LEDs.
If you’re interested, you can find instructions and 3 versions of ESPHome config here:
The basic version just needs a molex connection and 3 wires going to the Shelly (DC, GND, and W).
The other two include support for a pushbutton so you can still control the fan manually, and different combinations of 3 LEDs.
I also have 3D printed enclosures for all 3 versions.
Is the molex version even still available though?
My understanding is that there is a molex adapter available. It was included for awhile, maybe still is.
You’re right - AC Infinity AC-ADQ3 UIS TO MOLEX PORT ADAPTER DONGLE
Haven’t done anything beyond finding that but will get one on order
