Ac Moovair
Hi, I order a MoovAir AC and it’s not wifi. they can sell the wifi module but i don’t think home assistant have an integration ( or maybe it’s on a different name ? )
If not I could use an IR blaster but does anyone have a easy way to setup de IR blaster ? I don’t want to learn all the possibility of all the button …
do you have a reference for the wifi module ?
is it : https://cdn.master.ca/documents/en/technical-bulletins/residential/moovair/thermostats/_2_WiFi+Moovair.pdf
I think so yes !
@devzwf Why ?
I run a moovair heat pump with broad link Broadlink - Home Assistant and SmartIR GitHub - smartHomeHub/SmartIR: Integration for Home Assistant to control climate, TV and fan devices via IR/RF controllers (Broadlink, Xiaomi, MQTT, LOOKin, ESPHome) since 2020.
Thanks ! This is what I did. There is no
Moovair in smartir witch code did you used ? I think I took a Midea one
i scan all the code myself in HA, I can share it to you if you wish.
I order a SLWF-01 WiFi Air Conditioners control module | ESPHome | Home Assistant | SMLIGHT Official Homepage
will see if it is working.
and BTW
works , did not test yet to see if it is fully local but works
Heck yeah, SLWF-01 works perfectly for me! Thanks!
What Moovair unit do you have? I might get a Meridian heat pump but I would like to be able to add it in Home Assistant.
