AC voltage regulate water heater
hallo. want to do heat op a big water tank 300L with my surplus solar power.
i finally found some component’s i trust will be able to adjust the power to the heater element but need to controller it but cant find the bedst way to do it :confused:
i thing the bedst way is som kind off pwm controller but maybe you know better. :slight_smile: :laughing:
i’m pretty new to esp setups but i’m up for the challenge
i want to add som temperature sensorens to so i can see the temps inside so home assistant and it will be cool if i can add them to a single esp
the part https://vi.aliexpress.com/item/4000062425218.html?spm=a2g0o.cart.0.0.6a3038daIhgrDu&mp=1&gatewayAdapt=glo2vnm
i am pretty sure i want to use a esp32 30PIN CH9102X but maybe there is a better device
the Three phase AC voltage regulators needs on of 3 types of input to adjust the power out
4-20mA,
0-5Vdc,
0-10Vdc,
aliexpress tags:
Three phase AC voltage regulate module transformer power regulator thyristor dimming power regulate temperature control heating
