Hello, I have a problem I’m trying to solve all day. I have Homeassistant installed on docker on a Raspberry PI and can’t access the configuration.yaml file. When I look in my docker folder I just see 2 cryptic files. It tried to acces it with docker-compose but that also didnt work. Does somebody have a solution, that hasn’t been mentioned before? Thank you in advance.
You mapped /config
with either the docker run
command, or your compose file. What did you map?
I think its the docker run command
And…?
What was that command? We can’t help you if you don’t tell us things
Ok, sorry for that. I’m new here. I tried to install docker compose, but it didn’t work. I used the standard settings. To clarify I can’t find any .yaml file. Since you listed two options adn docker compose didn’t work I would assume its the docker run comman. If I missunderstood something (I certanly did) please correct me. Thanks
I looked somethink up, I don’t know if it’s the right thing, but in the terminal it says:
"Mounts": [],
There aren’t any.
See the docs for what you should be doing.
I’d 100% recommend compose files over the command line.
Hey, I looked into it. I looked in the docs, and I found This
admin@JannesPi:~ $ docker run -d \ --name homeassistant \ --restart=unless-stopped \ --privileged \ -e TZ=Europe/Berlinadmin@JannesPi:
This just pops out this error message:
"docker run" requires at least 1 argument.
See 'docker run --help'.
Usage: docker run [OPTIONS] IMAGE [COMMAND] [ARG...]
Create and run a new container from an image
I also have a general question, what even is the /config file, where should I paste it and why do I need it. I’ve also asked a Ki, I google, etc.
Sorry if I am a bit dumb, but thanks anyway.
Did you look at the link?
Your run command should have more:
docker run -d \
--privileged \
-e TZ=MY_TIME_ZONE \
-v /PATH_TO_YOUR_CONFIG:/config \
--network=host \
ghcr.io/home-assistant/home-assistant:stable
Replace MY_TIME_ZONE
and PATH_TO_YOUR_CONFIG
Yeah sorry, my fault.
I forgot to paste the changed version here, but I’ve ran it in the terminal.
Here’s the code that i ran:
docker run -d \
--privileged \
-e TZ=Europe/Berlin \
-v /usr/config:/config \
--network=host \
/config
is a folder, not a file. This folder is where HA stores all of it’s configuration and data. It will contain a number of folders and files, including configuration.yaml
Using the command you posted above, it will be in the folder /usr/config
on your host… Assuming it (Docker) is allowed to write to that location.
You can try here for a working (but not the most basic) Docker Compose file… https://github.com/Fraddles/Home-Automation/tree/main/Home-Assistant
That’s a very strange choice of /usr/config
. You shouldn’t pick locations under /etc
/, /usr
, or /var
(or /tmp
). Create your own folder (for example, I use /data
) or use something under /home
This will create a new homeassistant installation, so I need to remove the old on, right?
It says the container name is already in use and the docks say it will create a new one…
You can rename the running instance (named homeassistant
) and stop it. Delete it later when the new instance is in place and running.
sudo docker container rename homeassistant homeassistant_old
sudo docker container stop homeassistant_old
Thanks that all works now!
