Is there any magic I can do to access the /backup directory from within node red on a default HASSIO install.
The āfile inā node should give you what you want.
To access a file in the backup directory, put ā/backup/ā in the Filename field.
Are you trying to read one of the .tar files?
Thanks - yep eventually got google drive set up (the oauth stuff was hateful - eventually found out one of the problems was using chrome - worked when using safari
Now want to upload backup files to google drive (I know there are other ways )
I tried to access the file using the file node and get
āError: ENOENT: no such file or directory, open ā/backup/e9ad27d9.tarāā
The file exists and have tried other nodes and lways get ENOENT )
I believe the problem is node red not having read access to the directory
I am running hassio
you can easily get into the node red container and see for yourself. I wasnāt aware that the add-ons were bind mounting the backup directory.
thamks - a naive question how do iv get into the node red container. i can see the nodec red file system but thast is through logging in via ssh
Docker commands.
yep - thanks - still coming to terms with hassio and docker. once i work itv out i might write dome doco on this as it is not clear to me and not obvious where it is documented
I still donāt know how to access this /backup, however I have created a pull request on the addon to add /backup access natively (as /share and /config are currently)
Do you have a link to the PR?
Iāve been able to access /config/www using /local but havenāt had any luck access /share, how do you go about that?
Currently trying to do the same (accessing the backup folder from Node-red).
Iām able to see all other folder and files:
"_msgid": "c35b0070.9d1b1",
"payload": 1613224779122,
"topic": "start_backup",
"files": [
".dockerenv",
"bin",
"config",
"data",
"dev",
"etc",
"home",
"init",
"lib",
"libexec",
"media",
"mnt",
"opt",
"proc",
"root",
"run",
"sbin",
"share",
"srv",
"ssl",
"sys",
"tmp",
"usr",
"var"
Anyone having a solution or success with this. As many others I would like to move my snapshots to an external device / NAS. For simplicity, I donāt want to create some script on my NAS (do all in one place)
Would it be possible to add the share in Portainer?
