Hi all,
Im trying to add Google Nest to the home assistant. For the last step i gotta give Home assistant permission to monitor & control the devices. After doing this, i gotta select an account. After selecting the account I get an error message:
Access blocked: home-assistant.io has not completed the Google verification process
home-assistant(dot)io has not gone through Google’s verification process. The app is currently being tested and is only accessible to developer-approved testers. If you believe you should have access, please contact the developer.
If you are the developer of home-assistant(dot)io, view the error data.
Error 403: access_denied
I tried to add an screenshot, but the channel dont let me.
Is there something i did wrong in the configuration, or are there additional steps needed to take?
Many thanks!
(This error message has been translated from Dutch to English so the grammar might be not 100% correctly)
- Google Nest - Home Assistant Problem occurs at “link Google Account” step 5. (bewerkt)
