Hi
I have a DS423+ and I have an issue with access control.
I have a raspberry Pi hosting a Home Assistant instance. I use reverse proxy on the Synology NAS to access Home Assistant. To secure this, I use access control to only allow some IP adresses. However, on Home Assistant, I set up a link between Home Assistant and Google Home with this tutorial : Google Assistant - Home Assistant (home-assistant.io) (manual setup).
With access control, Google Home and Home assistant can’t communicate. How can I allow these requests to Home Assistant ?
Thank you
