Access esphome thermostat from display
I have an esphome bang bang thermostat with a relay and an esphome display
I would like to increase and decrease thermostat temperature from the display
climate:
  - platform: homeassistant
    entity_id: climate.thermostat
I tried to insert a thermostat reference inside the display configuration (as above) without success
Do you have any hint?
Did you find the on_touch trigger and binary sensor set-ups?
The trigger needs to be on your display component (or binary sensor) not the climate component.
You would probably set up a “on touch, set target temp to current target temp + 1” with a climate control action.
