Hi everyone, I have RP4 with HA CORE installed via docker container. I would like to use the camera.record action to record from an IP-cam, on an external HD connected to the RPI4, but it gives me the following error:
Impossibile eseguire l'azione: camera.record Can't write /export/nas_5tb/ipcam_movies/prova.mp4, no access to path!
I add the following to the configuration.yaml file:
homeassistant:
whitelist_external_dirs:
- /export/nas_5tb/ipcam_movies
but when I restart HA it gives me the following error:
`The system cannot restart because the configuration is not valid: Invalid config for 'homeassistant' at configuration.yaml, line 23: Not a directory 'whitelist_external_dirs->0', got '/export/nas_5tb/ipcam_movies'
In the docker-compose.yaml file added the following below the home-assistant block:
services:
home-assistant:
volumes:
- ~/homeassistant/.homeassistant/media:/media
- /export/nas_5tb/ipcam_movies:/ipcam_movies
I don’t know how to proceed. Could anyone help me? Thank you.
