Back at the end of June 2021 in installed Hass.io and the instructions were at Raspberry Pi - Home Assistant
Everything worked fine and I had DuckDNS set to point back to my home’s IP address as assigned by the ISP.
I have my Chrome browser set to start up with a number of tabs, one of them being set to:
https://mydomainname.duckdns.org/lovelace
Quite a while back, this tab would not load and would have the error message “Unable to connect to Home Assistant.”
Due to work etc, I didn’t have time to troubleshoot it so I just left it as I hadn’t really set up too much, so there wasn’t too much to miss.
Anyway, I’m on holidays at the moment so I have a bit of spare time and I’m trying to trouble shoot why I can’t connect via that address.
DuckDNS and WhatIsMyIP show the same so it’s not DuckDNS sending it to the wrong IP Address.
I can log on if I go directly to the IP address http://192.168.178.122:8123/
My FritzBox router has ports 443 and 80 port forwarded as per instructions at Nginx Proxy Manager
Any ideas on what could be the issue? Sure I could just change my browser to point to the IP address directly, but I’m thinking it would be nice to put the HomeAssistant app on my phone and have remote access.
Thanks in advance.
