New to HA so this may be basic but I can’t find the answer.
I’m trying to add my Victron Inverter data via MQTT
I’ve found a great video on YouTube by Melon Monkey Garage but when I get to accessing my PI via a PC to add files my PI show up as a device & not a PC, so when I click on it it opens HA & doesn’t access the files. (Attached photos is what I need it look like)
I have Samba share/ file editor installed & running.
What I’m I missing??
The PI is an older 3 model B
Are you clicking the one under computer or the one under other devices? The first one should work. You can also type \\ip-address-of ha in the location field to access it that way.
Sorry the photo is what I’m after, currently I don’t have that view. HA only shows as “other devices” not a PC so when I open it I get straight into the HA, not the files I need to edit.
Attached photo shows the files I need to access.
Hope that makes sense.
Perfect I’m in!
Sorry I misunderstood your first response.
Many Thanks
Please don’t mark your “thank you post” as the solution. Mark the post that is the actual solution the solution. Not only does that help people find the right answer, it also gives credit to the person who actually helped you.
