I am using Homeassistant quite a while for basic lighting, heating and smart plugs without issues. However, there are some strange things happening when I am trying to access homeassistant via the browser of via the app, which I cannot understand:
on the browser, I can only access Homeassistant typing homeassitant.local. Typing the ip address 192.168.178.235 that I assigned to the raspberry pi 4 in the router (Fritzbox) and also in the homeassistant settings does not work. However, pinging homeassistant.local in the cmd gives
On the other hand, configuring the app with 192.168.178.235:8123/ I can access Homeassistant. -
I tried to set the ipv4 and ipv6 to automatic in homeassistant settings (instead of static ip), and then pinging homeassistant.local yields as before but with the address [fe80::50c3:452d:4478:712e%9]. However, I can still connect over the app with 192.168.178.235:8123/. With the browser, I can access homeassistant only via homeassistant.local.
Does someone know what I am missing or doing wrong? Thanks in advance!
