Hi all,
I am collecting some values from different sensors into a new template sensor to be able to beautify the presented information. The sensors are coming from the Miele integration and provide localized state strings, here “Baumwolle” in German:
I now have the issue that I cannot access those localized state strings in the template sensor. I can access either the original state (“cottons”) or the Localized attribute in English (“Cottons”) as it is shown in the Developer Tools States page:
My result:
I guess I am missing something here, but I could not find anything to change the behaviour. Is the picking of the right Localized attribute happening within the frontend only?
- name: washing_machine_program_info
state: >
{% if is_state('sensor.washing_machine_status', 'off') %}
Ausgeschaltet
{% else %}
{{ state_attr('sensor.washing_machine_programm', 'Localized') }}
{% endif %}
icon: mdi:washing-machine
attributes:
icon_color: >
{% if is_state('sensor.washing_machine_status', 'running') %}
blue
{% elif is_state('washing_machine_status', 'Program ended') %}
green
{% elif is_state('sensor.washing_machine_status', 'off') %}
disabled
{% else %}
red
{% endif %}
program_stage: >
{{ iif(has_value('sensor.washing_machine_programmabschnitt'), state_attr('sensor.washing_machine_programmabschnitt', 'Localized'), ' ')}}
program_end: >
{{ iif(has_value('sensor.washing_machine_ende_um'), 'Ende um ' + states('sensor.washing_machine_ende_um'), ' ')}}
program_remaining: >
{% else %}
{{ iif(has_value('sensor.washing_machine_verbleibende_zeit'), states('sensor.washing_machine_verbleibende_zeit') + ' min verbleibend', ' ')}}
{% endif %}
Servus,
I found the solution and wanted to add it since I could not find it easily by googling.
There is a method called “state_translated”. So just replace the states(“sensor.name”) call with state_translated(“sensor.name”) and it will use the locale you have configured for HA.
Hope this helps.
fascpt
(Filipe Correia)
April 29, 2025, 6:30pm
3
I’m using the Miele integration too and arrived here because of the same problem you are facing. Nevertheless, I can’t really figure out how to replicate the card you took the screenshot from the template code you pasted? Could you explain how do you apply that code as a template to the card? The structure doesn’t seem to be the typical one to be put into configuration.yaml file.
This is the adapted code I’m doing from yours:
state: >
Off
{% else %}
{{ state_translated('sensor.washing_machine_programm') }}
{% endif %}
attributes:
icon_color: >
blue
green
disabled
{% else %}
red
{% endif %}
program_stage: >
{{ iif(has_value('sensor.washing_machine_program'), state_translated('sensor.washing_machine_program'), ' ')}}
program_end: >
{{ iif(has_value('sensor.washing_machine_finish_at'), 'Finish at ' + states('sensor.washing_machine_finish_at'), ' ')}}
{% else %}
{{ iif(has_value('sensor.washing_machine_remaining_time'), states('sensor.washing_machine_remaining_time') + ' min left', ' ')}}
{% endif %}
scw2wi
(Walter Schlögl)
November 6, 2025, 8:00am
4
fascpt:
state_translated
It seems that state_translated is not working if the state is a timestamp.
Is there any timestamp translation working with Jinsa2, or does this need to be done manually by macro, Python or something else?
Sorry, this is a bit old already, I just wanted to share the full answer.
This is the template sensor:
template:
- sensor:
state: >
{% if is_state('sensor.waschmaschine', 'off') %}
Ausgeschaltet
{% else %}
{{ state_translated('sensor.waschmaschine_programm') }} {{ states('sensor.waschmaschine_solltemperatur') | float(0) | round(0) }} {{ state_attr('sensor.waschmaschine_solltemperatur', 'unit_of_measurement') }}
{% endif %}
attributes:
icon_color: >
{% if is_state('sensor.waschmaschine', 'in_use') %}
blue
{% elif is_state('sensor.waschmaschine', 'waiting_to_start') %}
blue
{% elif is_state('sensor.waschmaschine', 'program_ended') %}
green
{% elif is_state('sensor.waschmaschine', 'off') %}
disabled
{% else %}
red
{% endif %}
program_name: >
Ausgeschaltet
{% else %}
{% endif %}
settings: >
{% else %}
{{ states('sensor.waschmaschine_solltemperatur') | float(0) | round(0) }} °C • {{ states('sensor.waschmaschine_schleuderdrehzahl') }} U/min
{% endif %}
program_stage: >
{% if is_state('sensor.waschmaschine', 'waiting_to_start') %}
{{ 'Starte in: ' + states('sensor.waschmaschine_start_in') }}
{% elif is_state('sensor.waschmaschine', 'in_use') %}
{{ state_translated('sensor.waschmaschine_programmphase') }}
{% else %}
{% endif %}
{{ states('sensor.waschmaschine_verbleibende_zeit') + ' min verbleibend' }}
{% else %}
{% endif %}
program_end: >
{{ 'Ende um ' + states('sensor.waschmaschine_ende_um') }}
{% else %}
{% endif %}
and this is the mushroom template card to create the visual above
type: custom:mushroom-template-card
entity: sensor.dishwasher_program_info
icon: "{{ state_attr(entity, 'icon') }}"
icon_color: "{{ state_attr(entity, 'icon_color') }}"
primary: "{{ states(entity) }}"
secondary: "{{ state_attr(entity, 'program_stage') }}"
