Access repository file with FTP or Windows files explorer
I have tried using FileZilla to access in FTP mode and I can’t. I have also made several attempts with Windows Explorer and it does not work.
After many unsuccessful attempts to find a solution, can someone point me in the right direction?
HA is deployed on a Raspberry Pi 4 with an SSD.
Thanks a lot!
If you installed the Samba add-on, Windows File Explorer should work.
Thank you, everything is operational.
