I want to access the router directly from the left column of the user interface. To do this, I have added the following to the configuration.yalm file:
# Muestra el Router en la columna izquierda del frontend
panel_iframe:
router:
title: Router ASUS RT-AC87U
icon: mdi:router-wireless
url: http://192.168.1.1
The icon and the name of the router appear in the left column. However, H. A. rejects the connection.
It is probably the router and not HA rejecting the connection. I have a TP-Link router and tried to do the same thing with a panel iframe. In my case, the router forwards traffic to an Apache server, which sends it to HA on another computer. As far as I can tell, the router is set up so that it can only be accessed from inside the local network as a security measure. Even with the panel iframe, I think there is still something in the http header between the browser and router that the router picks up and knows the connection is outside the local network or forwarded. I tried briefly to change the headers when it was passed through the Apache server, but didn’t have much luck. That may be the direction you would need to go, but someone more knowledgeable than I would have to detail what you can do to fix it.
The web server is only accessible on the local network. It is not routed to outside. Many people do not want the additional complexity of dealing with an ssl certificate.
Despite the error message, all three links work correctly. I am not able to interpret the meaning of the message (my knowledge of English and H.A. is limited).
The “weblink” section of my configuration file is as follows.
# ModificaciĂłn del archivo configuration.yaml
# para añadir el componente Weblink
weblink:
entities:
- name: Router Asus RT-AC87U
url: http://router.asus.com/Main_Login.asp
- name: Iconos material desing
url: https://materialdesignicons.com/
- name: Calidad del Aire
url: http://aqicn.org/city/spain/pais-vasco/sondika/sangroniz/es/
panel_iframe:
router:
# type: weblink
However, the link to the router from the left column of the frontend with “iframe” still fails.
I don’t quite understand the differences between the operation of the two alternatives.
Except for a mistake on my part, the access protocol to my H.A. is “not secure.”
Access to the router by “iframe”, as can be checked in the configuration file, also uses the “unsecured” protocol.
Thank you for your interest, the matter is unimportant and, in addition, you have an alternative solution. However, I am interested in learning as much as possible about how Home Assistant works.
I have the same issue, Found the route page is required same-origin. then iframe was not allow to cross the different domain. I’ve installed the cros plug-in on the chrome, but it doesn’t work.
Sorry to revive 4 years later but this is the first result on Google and I figured out a way. My use case was that I found myself in a country with blocked websites and even VPN. Here’s what I did:
Install terminal & extension. Configure SSH (it won’t work externally because the port isn’t open)
Use ssh in the web terminal to escape the docker instance and login to your pi user
Install a terminal based browser to browse your router admin page. Lynx is lightweight but doesn’t support javascript, this won’t work with TP-link routers. I used brow.sh instead
