Access to external SSID failing for media
Text
https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/
Oh come on… You never hit a wrong key?
How would one deduct your post was a single key error?
Typing Text and then hitting Enter would be would be 5 keys.
When I sent this, the other one was not there…
And when I hit a wrong key, I use the delete to erase it and edit the document.
With the number of Spams currently hitting the server, I was making sure you are a person and not a bot.
Lots of things going on you may not have realized were going on.
Just saw the cross post myself
I have an external SSID connected by USB to either my router or my HS raspberry pi (same result).
Can someone identify what I m missing or what the issue is?
I believe a username and password are both required - i.e. you can’t connect using anonymous and no password. Try setting up a proper user for the share.
Can you please tell me how to do that?
anonymous was an already filled in default.
I can access the drive via Samba directly as “anonymous” without a password.
I don’t know how to make “users” or “shares”. I’m only familiar with Windows and Android…
That all depends on your router that hosts the share, that’s nothing to do with HA.
Mine has a config page that looks like this:
