Access to Hassio
Hi, I have my Hassio installed on Raspberry and connected to the network via cable. By typing in the browser the IP address of my Raspberry I can’t log in !!! The page appears to me "The page does not work 10.0.0.19 did not send data.
ERR_EMPTY_RESPONSE ". Please help me !!!
http://10.0.0.19:8123
You need the port
Does not work
Do you get the same response with http://hassio.local:8123
Are you sure that is the correct IP of your Pi?
Yes, the same result
Yes, I checked it both from the router app and from an app on my smartphone
I try to explain my configuration a little to understand better. I have a “SMART MODEM WIFI ADSL FIBRA TIM TECHNICOLOR TG789vac v2 TELECOM” modem to which an “Orbi Netgear RBR40” router is connected. Hassio is installed on a Raspberry Pi 3 Model B + and connected to the “Orbi” router via cable (IP: 10.0.0.19). Hassio worked well for a few days, only after an update did I have to restart it and then no longer found the connection. After several attempts I decided to reinstall Hassio and so it ended up working but while I installed the main ADD-ONs and then restarted I lost the connection again and I can’t log in anymore. I’m desperate … please help me!
Which Add-ons are you installing?
did you try connecting to
https://10.0.0.19:8123
https://hassio.local:8123
note the s in https
Thank you very much, apparently my problem was just the “s” missing. I entered!!!
