Hello world started!
>docker -v
/run.sh: line 4: docker: not found
>avrdude -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/addons/avrdude/Blink.ino.hex:i
avrdude: Version 6.3, compiled on May 8 2018 at 16:59:46
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: ser_open(): can't open device "/dev/ttyUSB0": No such file or directory
avrdude done. Thank you.
Hello world finished!
As I see - avrdude works but has no access to /dev/ttyUSB0, it really exists and I can to see it on page Hassis/System, button Hardware. For grant the access Google tells use command docker run -t -i --device=/dev/ttyUSB0 ubuntu bash. But I get error /run.sh: line 4: docker: not found. Please help with can't open device "/dev/ttyUSB0".
USB0 connected to Arduino. When I unplug Arduino, there is no USB0 device in info from page Hassis/System, button Hardware, therefore hardware is ok and name is correct.
On a PC with Linux Mint, this scheme works well.
@eXtatic - if your add-on is publicly available, please give me a link so that I can investigate it. Thank you
I would like to make sure of your plug-in was wondering how ever what is the simplest way to install it i have tried adding the Git to home assistant Add-in store but had no luck, I must be honest i have not read up at all on how to load addons manually, was hoping you could just give me the rough steps needed to do so.
