Hi everyone
When setting up HA, I used the kind of ‘wizard’ that you get on a fresh install to add 4x Daiken aircon units. 3 of them have disappeared after a router update, but I have no way of checking the config as when you set up in the wizard it doesn’t seem to write things like IP addresses into config.yaml
Where can I find the config related to these units that I set up with the ‘wizard’ during fresh install? Basically I just need to check and update the IP addresses.
(all 4x units are definitely online through the Daikin app)
Thanks - I have rephrased the topic as 'how to access the details of entities that were setup by the new home assistant ‘wizard’ that appears on a fresh installation.
I’m not sure if I’m phrasing the question correctly. On a fresh Hassio install the first thing it does is asks you to add devices (along with general settings etc). You get to add IP addresses and device type during this process - however the detail is not written to a config.yaml file.
So my question is, where is the data stored for devices added in the initial setup phase?
