Accessing Hass.io from LAN network
Hi all
Sorry I realize this may be more of a docker question rather than a Hassio issue, but I don’t know enough to find a solution.
So I followed the steps on the github page to create a Hassio container on Raspbian Stretch :
https://github.com/home-assistant/hassio-build/tree/master/install#install-hassio
I can’t figure out how I can access home assistant from another computer on the local area network.
I believe i can access the HA from the host ( I repeated the same process on a VM with Debian Host and I can access home assistant from the host).
How do I configure to be able to access on LAN?
Many thanks:)
It is already available on the LAN.
You just pop the IP address of the HOST into a browser.
http://ipofhost:8123
Perhaps I should have mentioned this in my topic. But I did try that without success.
Then you should probably check the logs for the service.
sudo systemctl status hassio-supervisor.service
journalctl -xe
Thanks for the help.
I checked the logs and indeed there was several warning and a few errors.
In hindsight I should have saved them for reference. But I did I clean install and it works fine now.
