I am planing to add a new wifi repeater upstairs and I was wondering how to configure it in order to access Hass.IO form both wifi (and connect to both some IoT devices).
The existing wifi have the following configuration:
SSID1: WiFi Downstairs
Router IP: 192.168.50.1
New wifi setting (plannning)
SSID2: WiFi Upstairs
Router IP: 192.168.50.2
The PCs and devices will be accessible “cross-wifi”. nit what abut HAss.IO?
At the moment I have Hass.IO on a Raspberry Pi, di I need to add a new Raspberry Pi upstairs too?, if I have wifi connected devices upstairs, will I be able to connect them simply to the wifi?
I have google NEst Mini downstairs, will I be able to access it form upstairs?
You don’t make it simple, because you don’t use the correct network terminology. If you mean with Router IP the IP address of your AP, it should work. If you mean with Router IP they each have a different gateway, it will not work.
Yes, that is on. You should have no trouble accessing your WiFi lights. It is all one network. In fact, I have 3 access points in my house, no problems at all.
In my case, all my devices are connected to the main Freebox network 192.186.1.254, whereas my Nest wifi (and its 2nd point which is also a speaker) is a subnet 192.168.86.1
I have succeeded to connect all the devices (except my Nest Protects) but the Nest WiFi is not recognized.
I wouldn’t like to make a bridge with my freebox because I will loose functionalities, neither I wouldn’t like to make a bridge with my Nest wifi because it will be not possible to have my speaker functional
I am very annoyed, isn’t really there no possibility in my case?
