A little background about my setup:
- I currently running CentOS 7.3.1611 with Docker installed
- I’ve successfully installed and ran HomeAssistant within Docker
- Port 8123 is opened on my server and have verified it on portchecker sites
- I used DDNS that came with my router and have been successfully accessing applications on my server remotely via web browser
Docker Images
$ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
fec6f11b3e12 homeassistant/amd64-hassio-audio:14 "/init" 48 minutes ago Up 48 minutes hassio_audio
75541d43f1c3 homeassistant/amd64-hassio-cli:25 "/init /bin/bash -c …" 48 minutes ago Up 48 minutes hassio_cli
b54c4996a732 homeassistant/amd64-hassio-dns:9 "/init coredns -conf…" 48 minutes ago Up 48 minutes hassio_dns
63f8e85f0a16 homeassistant/amd64-hassio-multicast:2 "/init" 48 minutes ago Up 48 minutes hassio_multicast
52b24db9faa6 homeassistant/amd64-hassio-supervisor "/init" 49 minutes ago Up 49 minutes hassio_supervisor
I’m having trouble accessing the front end for example, http://myhomeassistant.dyndns.com:8123.
Error showing from Firefox is
Unable to connect
Firefox can’t establish a connection to the server at myhomeassistant.dyndns.com:8123.
Firewall rule is opened as confirmed by portchecker.
$ sudo iptables-save | grep 8123
-A IN_public_allow -p tcp -m tcp --dport 8123 -m conntrack --ctstate NEW -j ACCEPT
The script I used to install homeassistant is listed in the [installation page](curl -sL “https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh” | bash -s) of homeassistant. Once ran it started homeassistant in docker so there isn’t a need for me to run the following command. I don’t know if it has something to do with the “-net=host” option.
docker run --init -d --name="home-assistant" -e "TZ=America/New_York" -v /PATH_TO_YOUR_CONFIG:/config --net=host homeassistant/home-assistant:stable
Any idea?
