cd /srv/homeassistant/src/open-zwave-control-panel/
sudo ./ozwcp -p 8888
But when I run “sudo ./ozwcp -p 8888” it throws an error:
2017-03-11 22:45:26.368 Error, Cannot find a path to the configuration files at ./config/. Exiting…
2017-03-11 22:45:26.369 Error, Exception: Options.cpp:91 - 1 - Cannot Find Configuration Files
Error: Options.cpp:91 - Cannot Find Configuration Files
looking at what’s in the folder, I can see:
pi@HomeAssistant:~ $ ls /srv/homeassistant/src/open-zwave-control-panel/
config Makefile ozwcp.h test.sh webserver.h
cp.html openzwavetinyicon.png ozwcp.html testusb.sh webserver.o
cp.js ozwcp ozwcp.o TODO zwavelib.cpp
LICENSE ozwcp.cpp README webserver.cpp zwavelib.o
There is a config file in there. I don’t really know where to go from here.
I’ve installed the all-in-one installer this past month so /srv/hass/src/open-zwave-control-panel/ is of no use.
In my open-zwave-control-panel directory, I have: zwcfg_0xc28fd2ed.xml
I wonder if that’s what it’s looking for. You should have something that starts with zwcfg and ends in xml - the middle part depends on the ID of your zwave controller.
In my config directory, I have a couple dozen subdirectories organized by vendor.
Should I remove all the files and try it from scratch? Funny though, I didn’t chose where the files went to begin with so how could it have gone to the wrong location.
My OZW_log also states that it failed to setup the network key. Would that have any bearing on this situation?
