Hello community.
I´m new to home assistant.
My setup looks like this:
Raspberry Pi 3 b+
128 GB micro SD
Whenever i try to set up the system i can´t log in to the home assistant url.
Pinging homeassistant.local shows the correct IP.
I´ve already connected a keyboard and a monitor. The HA boots with no errors. I triple checked the URL and reinstalled the system in 32 bit (also switched from etcher to raspberry Pi imager and used different sd cards).
Nothing i do makes a difference.
I can´t get onto the url using dns or the IP.
Whats even weirder is that i CAN open the observer url just fine.
Any ideas on this?
With kind regards
Evykhait
