Accidental switch off Sonoff S26 smart plug
New to the whole automation scene, so please be gentle.
I managed to setup my Sonoff NSPanel Pro. First I just want to familiarize myself with the whole aspect integration and all.
During this I noticed that by just tapping the Sonoff S26 Icon it switches off. This is very disturbing.
Is there somewhere a setting that prevents accidental switching off?
Thanks.
Where is this icon located? In the sonoff app? In the HA dashboard? Somewhere else? :thinking:
On my HA dashboard and on the Sonoff NS Panel pro. On the later I have the problem. On the HA Dashboard it is ok.
Imago’s do not need to have it displayed on the NS panel. Is there a way to have it removed from the NS Panel, but still have it on my HAvDashboard?
So your problem is neither with home assistant nor the sonoff s29 mentioned in the title but with a sonoff ns panel which runs which *ware? :thinking:
I suggest you to spend couple of minutes on how to ask good question so that you actually get help. For now I (and probably others) still have no clue what your actually problem looks like :person_shrugging:
I do apologize for not asking an understandable question and also that I misunderstood that this is only about Home Assistant. I thought the Hardware subtopic was the correct place. I will have a look elsewhere.
It’s probably fine and people here will/want to help you for sure (that’s what this community is all about).
But to be able to help you the readers need to understand what’s wrong - and that is not clear for now at all. It seems your problem is actually with the sonoff ns panel. Maybe put this in the title of the post? Then information about the (firm)ware you are running/cobfuguration and maybe even a screenshot of the screen/icon in question too…
People really only can help if it is understandable what your problem is about
Let me try to be more specific. On the screen of my Sonoff NSPanel Pro is my Sonoff S26 visible. If I tap it it will be switched off. For obvious reasons I do not want this. I do not even need this button (to be visible) on my NSPanel, because I have it on my dashboard in Home Assistant.
Is there a way to remove the S26 from my NSPanel without removing it from Home Assistant?
I noticed an option in the eWeLink App to toggle LAN control. Could this be an option?
We can only work with the info you have provided, and it’s been pretty sparse so far. So, tell us more about how you’re displaying things on the NSPanel.
Is it mirroring your HA dashboard? If yes, the answer would be to create a separate user/dashboard for that panel (without the S26).
Is it using their app? If so, there should be an option to choose what devices are displayed on that dashboard. Judging by your screenshot, you’re using split screen from their app:
Syncing Existing Devices: If you already have devices connected to your eWeLink account, you can sync them to the NSPanel Pro by selecting “Split Screen” Settings in the App and choosing which devices you want to display on the panel.
You can edit what is displayed on the app itself according to their docs (scroll down to the Syncing Existing Devices section)
PS, I know you’re new and all that but:
is standard behaviour for all lights and switches. Obviously it all depends on what you have connected to that switch, but that is how devices generally behave.
Thanks, your suggestion of an option to choose what is displayed did it.
Great that it all worked out for you!
Please consider marking my post above with the Solution tag. It’s the custom of the community to assign the Solution tag to the first or best post that explains the cause of the problem and provides a solution.
By setting the Solution tag it will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions.
For more information about the Solution tag, refer to guideline 21 in the FAQ
