As the title says i accidentally overwrote the firmware on my zigbee dongle (sonoff zigbee 3.0 usb dongle plus) when playing around with esphome.
I immediately noticed that none of my zigbee was working (not any wonder here). I went to re-flash the latest correct firmware (tried both v. 20221226 and v. 20230507), thinking that would solve my issue.
However after flashing i was able to enter my zigbee2mqtt dashboard in home assistant, however i still could not turn on or off any zigbee lights. However if i used my hue dimmer i could visibly see the lights turn on/off in the dashboard.
I think it’s odd that i can see values changing but not control it?
I’ve tried rebooting HA and unplugging my sonof zigbee dongle many times, but no luck.
In the zigbee2mqtt logs i get the following:
[23:57:33] INFO: Preparing to start...
[23:57:34] INFO: Socat not enabled
[23:57:37] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:error 2024-02-23 23:58:14: Publish 'set' 'state' to 'Hue Bedroom Closet1' failed: 'Error: Command 0x001788010c44045e/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
Zigbee2MQTT:error 2024-02-23 23:58:14: Publish 'set' 'state' to 'Hue Bedroom Closet2' failed: 'Error: Command 0x001788010c43e863/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))'
This is my configuration:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt: {}
serial: {}
zigbee_herdsman_debug: false
And zigbee configuration:
"external_converters": [],
"devices": [
"devices.yaml"
"groups": [
"groups.yaml"
"homeassistant": true,
"permit_join": false,
"mqtt": {
"base_topic": "zigbee2mqtt",
"user": "xxx",
"password": "xxx",
"server": "mqtt://core-mosquitto:1883"
"serial": {
"port": "/dev/ttyUSB0"
"advanced": {
"log_level": "warn",
"pan_id": 6754,
"channel": 11,
"network_key": [
1,
3,
5,
7,
9,
11,
13,
15,
0,
2,
4,
6,
8,
10,
12,
13
"availability_blocklist": [],
"availability_passlist": []
"device_options": {},
"blocklist": [],
"passlist": [],
"queue": {},
"frontend": {
"port": 8099
"experimental": {}
At this point i’m kinda stuck. Any help would be greatly appreciated!
