Hi all
I’ve just got 2 Accio filament smart bulbs but having issues with brightness control in Home Assistant.
I connected them through Tuya app easily, which has controls for onoff and brightness.
When importing the lights into Home Assistant in the TuyaLocal integration they only allow onoff, no function to control brightness.
I’m fairly new to this, so welcome any suggestions. I’ve taken a look through Tuya developers console and home assistant light information, and cant see how to set up bulbs for brightness if it wasn’t imported during the integration.
There is also no references to using these bulbs in Home Assistant and Tuya.
I have bought four accio filament bulbs, oddly two of them show up differently in the Smartlife app. Two show as proper Accio filament bulbs, the other were detected as more generic bulbs. I can control the brightness for all through smartlife fine though. They look identical and were bought together, so very strange.
However when I added them all via localtuya, the first two (the ones that showed up as the right bulbs) work great with the settings above so thankyou. The other two had completely different dp values available and I wasn’t even able to select any of the above! The only way I got it to work at all was with minimal settings and choosing 0-255 for brightness, but this doesn’t give full range and seems inconsistent!
