I have been searching for a accurate/reliable presence detection solution, but I have not been able to find one or I am messing it up (without knowing). Is there a solution is that is reliable?
First one is GPS tracking: all fine and well, but this does not (I think) work without Nabu Casa or a VPN solution. Why? Well, the Home Assistant application can’t update your location if you are not able to connect to HA. A permanent VPN could be a solution, I could probably live with that, but my wife (and kids) will not be liking that solution. And it is kind off fiddly: connection issues etc…
Router tracking: I have a Ubiquity Dreammachine a an extra AP of Ubiquity in house. They integration is flaky at best, will report my device as away will I am sitting on the couch doing nothing. Maybee combined with a timer this could work some what. I am not yet convinced.
Router tracking 2: Using NodeRed flow to check werther specific MAC addresses are connected works. But the implementation fails almost weekly: I had Unifi controller changes that needed attention before it got working again. Unifi setup some rate limiting on logins, so checking every 10 seconds will cause the limiter to trigger. In my case it took a few hours before I was able to check on Unifi again, very annoying.
Other problem with this, is that the call I was able to make overwrites any attributes to a person entity. So I’ve set a picture to me and my wife. When NodeRed flow updates, the picture is no longer visible when viewing the entity. Updating person helps, until the next NodeRed update (every minute).
This could maybe be fixed with a better API call, I was not able to figure out how to update a state without overwriting any other attributes.
Ping: I was hoping this would be the one, untill I read that modern phones usually do not respond when they are idle.
I was also not able to really implement this. Created a yaml file including this config:
- platform: ping
consider_home: 0:05
hosts:
me_ping_tracker: 192.xxx.xxx.xxx
her_ping_tracker: 192.xxx.xxx.xxx
And this in the configurastion.yaml:
device_tracker: !include device_tracker.yaml
For some reason it does not show the “me_ping_tracker” anywhere in entities. The test device trakcer I have created and deleted from config are still there and do nothing. Restared HA several times, no avail.
My question is: how do you handle presence without Nabu Casa or a permanent VPN connection?
Am I missing something obvious? Because for me this is really the essence of HA. Without presence detection I would not want to automate anything (turn on lights/heating when I am not home is not desired).
I see some posts about it, but usually they use GPS tracker but do not mention a VPN or Nabu Casa.
