I am having no luck with the Accuweather integration setup. I have an api key that functions fine using the accuweather website to test. The dialog box asks for a name field. I am not sure what goes in that field. I tried the project name I supplied to accuweather when I setup my ‘app’ (i.e. applied for the api key). When I hit submit in the integration dialog box, the error returned is "Failed to connect
" I don’t see any entry in the logbook with any details. I am running HA container on ubuntu 18.04 server.
I know this is old, but I am having the same issue with a “Failed to connect” message. Did you ever figure this out?
Hi Aaron,
I was eventually able to get it working but it has been so long I can’t remember what the fix was. I will take a look at my configuration in the next time I have a chance and try to get back to you with anything that might help
Hi, Im having same issue while trying to setup AccuWeather integration - Im sure my Key is correct… Anyone any idea please?
