In the process of making my Emachines V700 (Acer H5360 clone) working with Google assistant, with Home Assistant and ESP8266 (Wemos D1 Mini).
Almost every Acer projector uses same commands, you just need to find pin-out of RS232 of your specific model.
My first test was done in an very old laptop, so the only terminal SW that worked in xp was Termite.
I was able to power ON and OFF projector using RS232, and commands as showed in image:
In my case, the PIN-out od the DIN 3-Pins in projector is as followed (used a straight cable, so I had to cross TX with RX):
So my next step is to connect Wemos D1 Mini to a TTL-RS232 IC.
I will use the max233 (no capacitors needed) and because that’s what I have available at home electronics junk
I will use GPIO1 and GPIO3 for that from ESP8266.
I will keep you all posted for more developments, cause I know i will step in some nails regarding SW.
