Next step I wanted to combine the 2x2 cards in the upper left corner to make it look like like this:
I can’t get it done! Can someone please push me into the correct direction?
To avoid conflicts with the next step I have in mind, eventually I want to stack multiple 3x3 grids. Maybe some will also have the bigger 2x2 card. Something like this:
In the 2x2 card I eventually want to create a custom card with multiple (dynamic) content. Like weather, room temperature and humidity, etc.
I have pasted my current code below but I think it’s not much use as a base. I’m pretty sure I will have to use more advanced options like layout-card or custom-card.
I would really appreciate a push into the right direction.
custom layout-card?
You can use it as a regular card, building custom grid within it, or you can can use it cusom dashboard layout, putting cards wherever you want within entire dasboard.
Referring to example you gave in the very first post, you could do something like:
type: custom:layout-card
layout_type: grid
layout_options:
grid-template-columns: 33% 33% 33%
grid-template-rows: auto auto auto
grid-template-areas: >
"1 1 2" # this section defines areas to put cards into
"1 1 3"
"4 5 6"
cards:
- type: button
show_name: true
show_icon: true
tap_action:
action: toggle
entity: light.living_room
show_state: false
view_layout:
grid-area: 1 # this defines where in the grid this particular card will be placed
- type: button
show_name: true
show_icon: true
tap_action:
action: toggle
entity: light.dinning
show_state: false
view_layout:
grid-area: 2
# and so on for every defined grid call
Thank you so much! Really, I am so grateful. I tried so many things and the results felt so far away from what I wanted. Your code did it! It feels a little frustrating too because I think I was at one point at the right track but failed in the end.
just 2 columns, 1 (right) 100% height, left column having content in the top row vertically aligned to the top and the bottom row vertically aligned to the bottom.
this is what i have now but its not working. Everything is in the first column.
- type: custom:layout-card
layout_type: grid
layout_options:
grid-template-columns: 33% 67%
"1 2"
"1 2"
"3 2"
You have some misalignment of rows, it should look like:
layout_type: grid
layout_options:
"1 2"
"1 2"
"3 2"
Then perhaps it is not needed to have “1 2” duplicated as this represents same cells in the grid. Finally symptom you gave looks to me like you forgot to add view_layout: option to actual cards aand then all of them are placed outside of grid, within available screen area.
