is there any possibilities to acknowladge alerts which are sent to iOS? I like to push a button on my Apple Watch to silence the alert till the correct state is reached.
Or do i have to work around with an input_boolean? But how do I check for multiple states in an alert?
Here is what I have in my configuration. I have a few alerts for doors, and it will silence the alerts that are on (which works for me, but I’m sure it can be improved). From the documentation, it appears the behavior is the same whether it is a phone (only thing I have configured), tablet, or watch.
Alerts are different than automations. Alerts are always enabled.
Alerts will always start as “idle”.
When triggered, the alert transitions to “on” and “message” is sent (unless “skip_first” is set to true).
Messages “repeat” if defined.
If the “can_acknowledge” flag is set to true, then the alert can be turned “off”.
When the trigger entity returns to normal state, the alert returns to “idle” and “done_message” is sent.
