Good day all.
I have recently added the WXSPONEFLS Rollease Acmeda Automate integration to my Home Assistant instance. I am on the very latest update (several hours old in fact). I installed the Wifi device, blinds are working fine through it and the remote.
As soon as I installed the integration, the two blinds were found and I created a couple of automations to utilise them. Unfortunately, some time in the last few days the entities stopped responding. I checked the device IP and it was the same, rebooted, removed and re-added the integration, all to no avail.
The app seems to have limited logging or diagnostic abilities, and there is no obvious log entry that might pertain to it.
I noticed the very latest update had a Homekit fix, so was hopeful that might have something to do with it, but still won’t find the blinds. I found a Blog entry about adding a section into configuration.yaml, but once again no change.
Is anybody able to help or give me something else to check?
Below are the only errors in the log.
File "/usr/src/supervisor/supervisor/store/git.py", line 195, in pull
raise StoreGitError() from err
supervisor.exceptions.StoreGitError
22-04-15 12:49:37 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-45366' coro=<Repository.update() done, defined at /usr/src/supervisor/supervisor/store/repository.py:106> exception=StoreGitError()>
File "/usr/src/supervisor/supervisor/store/git.py", line 155, in pull
await self.sys_run_in_executor(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/git/remote.py", line 886, in fetch
res = self._get_fetch_info_from_stderr(proc, progress,
File "/usr/local/lib/python3.9/site-packages/git/remote.py", line 750, in _get_fetch_info_from_stderr
proc.wait(stderr=stderr_text)
File "/usr/local/lib/python3.9/site-packages/git/cmd.py", line 502, in wait
raise GitCommandError(remove_password_if_present(self.args), status, errstr)
git.exc.GitCommandError: Cmd('git') failed due to: exit code(128)
cmdline: git fetch -v --update-shallow --depth=1 origin
stderr: 'fatal: error reading section header 'acknowledgments''
File "/usr/src/supervisor/supervisor/store/repository.py", line 110, in update
await self.git.pull()
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 108, in wrapper
raise err
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 106, in wrapper
return await self._method(*args, **kwargs)
22-04-15 12:49:37 INFO (MainThread) [supervisor.store] Loading add-ons from store: 42 all - 0 new - 0 remove
22-04-15 12:51:21 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
22-04-15 12:51:21 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
22-04-15 12:51:21 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
22-04-15 12:51:21 ERROR (MainThread) [supervisor.store.git] Can't update https://github.com/home-assistant/addons repo: Reference at 'HEAD' does not exist.
22-04-15 12:51:28 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-04-15 12:51:29 ERROR (MainThread) [supervisor.store.git] Can't update https://github.com/hassio-addons/repository repo: Cmd('git') failed due to: exit code(128)
stderr: 'fatal: error reading section header 'acknowledgments''.
22-04-15 12:51:29 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-45461' coro=<Repository.update() done, defined at /usr/src/supervisor/supervisor/store/repository.py:106> exception=StoreGitError()>
raise err
future: <Task finished name='Task-45462' coro=<Repository.update() done, defined at /usr/src/supervisor/supervisor/store/repository.py:106> exception=StoreGitError()>
File "/usr/src/supervisor/supervisor/store/git.py", line 152, in pull
branch = self.repo.active_branch.name
File "/usr/local/lib/python3.9/site-packages/git/repo/base.py", line 797, in active_branch
return self.head.reference
File "/usr/local/lib/python3.9/site-packages/git/refs/symbolic.py", line 292, in _get_reference
sha, target_ref_path = self._get_ref_info(self.repo, self.path)
File "/usr/local/lib/python3.9/site-packages/git/refs/symbolic.py", line 201, in _get_ref_info
return cls._get_ref_info_helper(repo, ref_path)
File "/usr/local/lib/python3.9/site-packages/git/refs/symbolic.py", line 184, in _get_ref_info_helper
raise ValueError("Reference at %r does not exist" % ref_path)
ValueError: Reference at 'HEAD' does not exist
raise err
22-04-15 12:51:30 INFO (MainThread) [supervisor.store] Loading add-ons from store: 42 all - 0 new - 0 remove
Thanks,
Glenn.
