ACS712 over Analog Mux cd74hc4067 on A0
I get an error message in the ACS712 sensor section that I can’t solve.
I have the following hardware configuration:
ESP8266 NodeMcu.
I connected an analog multiplexer cd74hc4067 to analog port A0.
I use channels 0-3 at the A- Mux and the addressing is in the code below.
As an additional library I use the
In the ACS612 section, I get
-platform: cd74hc4067
an error message that I can not solve.
Can someone please help me?
Best regards
Achim
here is my code snippet
  # Analog Strommessungen an ACS712 Sensoren
  - platform: adc
    pin: A0
    update_interval: 120s
  - [u]platform: cd74hc4067[/u]
    number: 0
    lambda: |-
      auto acs712_sensor = new ACS712Sensor();
      App.register_component(acs712_sensor);
      return {acs712_sensor->current_sensor, acs712_sensor->power_sensor};
    sensor: adc_sensor
    - name: "Amperes"
      unit_of_measurement: A
      accuracy_decimals: 2
    - name: "Watts"
      unit_of_measurement: W
and here is all the code
substitutions:
  devicename: bigbox-lightcontrol
  upper_devicename: ESP8266_KUECHE_BigBox
  device_location: Kueche
  device_description:  BigBox Lichtsteuerung platform using ESPhome firmware
  ipaddress: 192.168.2.102
  last_update: "2023-05-15 18:54:12"
esphome:
  friendly_name: BigBox_LightControl
  libraries:
    - https://github.com/RobTillaart/ACS712.git
  includes:
    - acs712_component.h
esp8266:
  board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: !secret ESPHOME_API_KEY
ota:
  safe_mode: true
  password: !secret HA_OTA_PASSWORD
wifi:
  power_save_mode: none # none (default for esp8266), light (default for esp32), high
  ssid: !secret WLAN_ASUS_SSID
  password: !secret WLAN_ASUS_PASSWORD
  manual_ip:
    static_ip: !secret ESP8266_KUECHE_BigBox_IP
    gateway: !secret WLAN_ASUS_GATEWAY_IP
    subnet: !secret WLAN_ASUS_SUBNET
    dns1: !secret WLAN_ASUS_DNS1
    #fast_connect: on
  ap: # Enable fallback hotspot (captive portal) in case wifi connection fails
    ssid: "Bigbox-Lightcontrol"
    password: !secret WIFI_AP_PASSWORD
web_server:
  port: 80
  auth:
    username: admin
    password: admin
# Analog cd74hc4067 16 Channel Mux
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0: GPIO13
    pin_s1: GPIO15
    pin_s2: GPIO3
    pin_s3: GPIO1
# Sensoren am I2C Bus
i2c:
  # Pimoroni BME60 Sensor
  - platform: bme680
    temperature:
      name: "LedPanel BME680 Temperatur"
      oversampling: 16x
      filters:
        offset: -0.65
    pressure:
      name: "LedPanel BME680 Pressure"
    humidity:
      name: "BME680 Humidity"
      filters:
        offset: -0.065
    gas_resistance:
      name: "LedPanel BME680 Gas Resistance"
    address: 0x76
    update_interval: 60s
  # BH1750 Lux/Lumen sensor
  - platform: bh1750
    name: "LedPanel BH1750 Pflanzenspitze Illuminance"
    address: 0x23
  - platform: adc
    pin: A0
  - platform: cd74hc4067
    number: 0
    lambda: |-
    sensor: adc_sensor
    - name: "Amperes"
    - name: "Watts"
    number: 1
    sensor: adc_sensor
    update_interval: 3600s
    number: 1
    sensor: adc_sensor
    number: 1
    sensor: adc_sensor
# 2 HauptLED schalten nur On/Off
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO14
      mode:
        input: true
        pullup: true
      inverted: true
    name: "Button LED 1"
  - platform: gpio
    pin:
      number: GPIO12
      mode:
        input: true
        pullup: true
      inverted: true
    name: "Button LED 2"
switch:
  - platform: gpio
    name: "2CH Relay 1"
    pin: GPIO14
  - platform: gpio
    name: "2CH Relay 2"
    pin: GPIO12
edit:
i think i found a solution… i try to use only the cd74hc4067 lib amd some filters… maybe thatts the right way
