I am having trouble getting alexa to find the matterbridge instance. I have setup the add-on and I can see the logs and QR code.
Scanning the QR code shows “Connecting to your device…” and then eventually fails with the message “Alexa can’t connect to your device”
I suspect that this has to do with my network/VLAN config where my alexa is on the 192.168.30.x subnet and my HA installation is on the 192.168.50.x subnet.
I have firewall (OPNsense) rules to allow any device from the .30 subnet to access the HA server over TCP/UDP on all ports (for testing).
I also have the mDNS forwarder service enabled and working for ESPHome, where the ESPs are on the .30 subnet and ESPHome is on the .50 subnet.
Does anyone know of anything else that I might need?
Hey so this isn’t your exact scenario, but the home assistant docs for matter say that devices must be in the same LAN/VLAN as HA. Googling around shows similar results. I thought I’d seen something more official about matter not supporting different vlans (!!) but can’t find it now.
I know people handle the subnetting different ways. In my case HA, matterbridge, & alexa devices are on the main trusted vlan. Other iot, esphome, etc devices are on a separate ssid & subnet. Home assistant is of course able to reach them, mDNS forwarding works, but then everything is open between matterbridge & alexa.
Thanks for pointing that out for me. I’ve always considered HA as more “trusted” than all the devices and appliances, perhaps it is time to demote HA to the IoT VLAN.
You can run it as a separate docker container, addons are mainly docker containers.
I also ran HA in Docker for years but thinking about moving to HAOS.
