I’m wishing to tidy up my config so if anyone can assist with turning the two automations below into one using a data_template/service_template, that would be appreciated. I see lots of variations of it in the forums but having trouble figuring out mine. I’ve got a lot more of these touch screen commands to add for entities that aren’t natively in HA as MQTT items so condensing them into one would be hugely helpful.
@bradyn12 Thank you, that is good to know but I need something that is ‘looking’ at the payload of my publish command. If I send on, turn on light. If I send off, turn off light. I found the code below but don’t have the skills to tweak it for my needs.
- id: do_some_on
alias: "Do Something"
initial_state: 'on'
platform: mqtt
topic: "hermes/nlu/intentParsed"
- service: script.turn_on
data_template:
entity_id: >
{% if (trigger is defined) and ('radio in kitchen' in trigger.payload) %}
script.radio538
{% elif (trigger is defined) and ('movie time' in trigger.payload) %}
script.turnon_movie_light
{%- else -%}
script.snips_say_notok
{% endif %}
@bradyn12 Legend Sir! Thank you. That is exactly what I was looking for and and has allowed to go crazy this evening adding switches and locks too using that methodology.
