I have an automation trouble. It’s literally the second one I’m trying to create and can’t make it work:
- platform: modbus
scan_interval: 0.5
registers:
- name: light
hub: wago
slave: 1
register: 12310
register_type: holding
count: 1
scale: 1
offset: 0
precision: 0
data_type: int
input_number:
target_temp:
name: Target Heater Temperature Slider
min: 0
max: 3
step: 1
unit_of_measurement: bulbs
icon: mdi:target
- alias: Read from modbus to slider
platform: state
entity_id: sensor.light
service: input_number.set_value
entity_id: input_number.target_temp
value: input_number.target_temp | int
It triggers every time I change value on modbus side (I can see that in logs) but it has no impact on slider so I’m guessing data section is wrong. What should it be to be correct? I want to pass value I read from register 12310 to set my slider at.
