I have a coffee machine that has an HA integration. I want to know if the last run program was the “milk clean” program, so if ran it last before turning it of I want to set a state “coffee machine clean”
However the machine doesn’t provide that data, however it outputs if its idle or doing something. The clean program takes 54-57 seconds, everything else takes some other amount of time.
So it goes idle, running (for x seconds), idle
I now want to set a state “clean” if the last “running” state took 55 (+/- some delta) seconds. If the last program took some other amount of time, set it to “dirty”.
Additional complication, when turning on it goes to running as well, but for a very short amount of time. It also changes from off to running instead of from idle to running.
Any pointers on how I can achieve this?
I’m technically inclined but rather new to HA, so any help would be appreciated.
This automation would also trigger if one of the other, non-cleaning, programs ran for longer than 55 seconds.
I think your trigger should be when the coffee maker’s sensor goes fromrunning and then you can calculate and test the time it was in that state in a template condition using something like this template:
{% set time = as_timestamp( trigger.to_state.last_changed ) - as_timestamp( trigger.from_state.last_changed ) %}
{{ time >= 54 and time <= 57 }}
