Action mode off and idle not displayed in mqtt climate thermostat with 2023.12
I have the following config for on mqtt thermostat that works very good, but after 2023.12 action mode idle and off, are not dispayed at all
hear is the config that i am using
mqtt:
  - climate:
      name: 1st Floor Thermostat
      unique_id: 1st_floor_thermostat
      availability_topic: "1st_floor_thermostat/thermostat/properties"
      availability_template: "{{ value_json.alive }}"
      payload_available: true
      payload_not_available: false
      temperature_command_topic: "1st_floor_thermostat/thermostat/set/targetTemperature"
      temperature_state_topic: "1st_floor_thermostat/thermostat/properties"
      temperature_state_template: "{{ value_json.targetTemperature }}"
      current_temperature_topic: "1st_floor_thermostat/thermostat/properties"
      current_temperature_template: "{{ value_json.temperature }}"
      action_topic: "1st_floor_thermostat/thermostat/properties"
      action_template: >
        {% if value_json.deviceOn == true %}
          {% if value_json.state == "off" %}
           heating
          {% else %}
           idle
          {% endif %}
        {% endif %}
          {% if value_json.deviceOn == false %}
           off
          {% endif %}
      mode_state_topic: "1st_floor_thermostat/thermostat/properties"
      mode_state_template: >
        {% if value_json is defined and value_json['deviceOn'] is defined %}
          {% set deviceOn = value_json['deviceOn'] %}
        {% else %}
          {% set deviceOn = false %}
        {% endif %}
        {% if value_json is defined and value_json['schedulesMode'] is defined %}
          {% set schedulesMode = value_json['schedulesMode'] %}
        {% else %}
          {% set schedulesMode = 'off' %}
        {% endif %}
          {% if deviceOn == true %}
        {% if schedulesMode == 'auto' %}
          auto
        {% else %}
          heat
        {% endif %}
        {% else %}
          off
        {% endif %}
      mode_command_topic: "1st_floor_thermostat/thermostat/set"
      mode_command_template: >
        {% if value == 'auto' %}
          {{ {'deviceOn':true,'schedulesMode':'auto'} | to_json }}
        {% endif %}
        {% if value == 'heat' %}
          {{ {'deviceOn':true,'schedulesMode':'off'} | to_json }}
        {% endif %}
        {% if value == 'off' %}
          {{ {'deviceOn':false,'schedulesMode':'off'} | to_json }}
        {% endif %}
      modes:
        - "auto"
        - "heat"
        - "off"
      min_temp: 5
      max_temp: 35
      temp_step: 0.5
      precision: 0.5
      retain: true
any help is appreciated
Thank you
