I have a device that sometimes crashes but is still pingable. It posts to mqtt data on a regular basis when it’s working. Is there any way to watch for lack of publishes over time and act on that situation? The acting part is easy, just don’t know how to code something to watch.
Set up a timer and an automation that starts it when HA starts.
Now set up an automation that triggers with the MQTT topic of the device you want to watch.
The action of this automation will be to reset the timer.
A third automation that triggers when the timer finishes should send you a message or some other way to indicate the fault or: flash light.
I’ll have to figure out the second part. Currently, when the device stops reporting, in this case Watts, the number for the sensor just stays the same.
What we’re aiming to do here is set up a timer that counts down to zero.
When your device sends a MQTT message, the timer will reset and start counting down again.
When your device fails and doesn’t send a MQTT message, the timer will eventually reach zero and trigger a notification so you are made aware of the failure.
In your config.yaml create a timer
timer:
mqtt_heartbeat:
duration: 00:10:00
#time formatted as hh:mm:ss will need to be changed depending on how often the device fails
Now create an automation to start the timer when Home Assistant starts.
In your automations.yaml
- alias: HA Startup
initial_state: true
- platform: homeassistant
event: start
- service: timer.start
entity_id: timer.mqtt_heartbeat
And now we want an automation that listens for your device’s MQTT messages and resets the timer
- alias: MQTT Listener
initial_state: true
- platform: MQTT
topic: path/to/your/devices/MQTT/publish/topic
- service: timer.start # restarts timer at its initial value
Lastly an automation that triggers when no MQTT message is sent and the timer eventually times out
- alias: MQTT Fail
initial_state: true
- platform: event
event_type: timer.finished
event_data:
- service: notify.dax333_your_notification_platform
message: "Devices MQTT has stopped !"
Thank you so much. That is perfect!
…but does it work ?
Works great, thank you.
- platform: MQTT needed to be lowercase.
